engine oil advice
R W
Amble,Northumberland
2001 E320cdi/ Sclass 2012 350cdi
What engine oil is recommended for the 2.9td or 300td. Are these engines happy to run on a 15/40 good quality mineral oil or do they require a synthetic oil. If the 15/40 is OK to use, what mileage would you recommend oil changes to be done at. What do other members use in these engines or what does MB recommend.
Regards
R W
R
R W
Parrot.
Its a 1997 2.9td dont know the MB model No for this engine.
FIBAMAN
TYNESIDE
C180,C180,E300TURBO DIESEL
I have been running my 98 E300 TD on Havoline 5 - 40 fully synthetic for the last 12 months. Changing every 10,000 miles regardless of service indicator (usually says I have another 3000 or so to go). Currently buying oil from cash & carry for £12.50 / 5 ltrs. Absolutely no probs. You should read the spec approvals on the oil container before you choose.
Parrot of Doom
Manchester
My oil change is about due, Mobil 1 is going in it.
R
R W
I am not really explaining very well what my question is.
I have this car in a former USSR country near the border of China. I have large quantities of good quality (as its imported direct to us from USA)Mobil15/40, for our industrial engines.
The Chinese import cheap copies of everything to here, mob phones, watches, anything you can think of they copy it.. The item will work for 3months & that’s the end of them, but they are hard to distinguish from the genuine product. For them to sell a cheap oil in a good original looking container would be very easy. I could go & buy what I think is a good quality fully synthetic oil & it may be absolute rubbish. I wouldn’t know the difference till I had engine failure. If the 15/40mineral oil is suitable for my engine I would use it even if it meant more frequent oil changes. But if mineral oil isn’t suitable I will try, maybe, to find a genuine synthetic or semi synthetic oil. Alternatively I don’t want to be carrying bottles of Mobil 1 back here in my luggage if 15/40 is OK to use. Maybe some of you guys with Sprinters could advise as this2.9td is the same engine I think.
Thanks for your replies so far.
R W
Parrot of Doom
Manchester
I wouldn't use 15/40. Too thick when cold.
Order some Mobil 1 from somewhere like opieoil. Its well worth it, your engine will last much longer.
R
R W
Thanks for the advice Parrot. I will try to find some genuine oil, as you say the 15/40 maybe to thick in cold winters like we have here.
