Engine Revs Up And Down
doubleflourish
New Registration
I Have A 1995 Model E 220 Mercedes Benz. Recently It Developed A Problem. The Engine, When Started, Revs Up And Down While Slow-working, And Sometimes Goes Off. My Friends Suggest Actuator Or The Air Flow Meter. What Is The Problem Really
Iratatic idle is often caused by the OVP relay, the voltage going to the control modules should be checked, also check the fuse on top of the over voltage relay
Malcolm
www.W140.co.uk&www.r129.co
