Engine Speed
Bill Ford
My brother recently acquired a '70 280SL (I think that's right) and he is not sure he is getting into top gear. What RPM should be showing in top gear at 70 MPH?
Hi Bill, I think that the gearing was 20mph per 1k revs
You can work it out if you wish
the back axle ratio used was one or the following the 3 axles depended on the gearbox fitted
10658 REAR AXLE,RATIO 1:4.08 OR 1:3.92
10659 REAR AXLE,RATIO 1:3.69
type49
That would be a 113 chassis number & called a "Pagoda". Not driven one for a few years but I would say between 3000-3300RPM.
B
Bill Ford
Thanks, guys, I think he is not used to high-reving engines and thought he was still in second gear or something. Ha! he told me he thought it was going to "blow up". ;)
