have a 1975 350 SL running on a Constant Injection System (CIS) fuel system, not K-tronic.
I have a engine running problem, my best way to describe it would be:-
If I can get the engine running ( from cold) it may run on 8 cyl. for 1-2 mins then onto 4 cyl then cuts out, or goes from 8 to off. If it restarts, it may be on 8, 4 or not start.
We have had the control unit (situated in the N/S/F wing) checked and is ok, (unless there has been a new problem occurred since it been checked) .
New pick up sensor located at the bottom of the dizzy.
Checked fuel relays, not got new ones but cleaned them and they seem to be working ok.
New HT leads etc.
Had a look at throttle body air flow sensor, seems to be working ok, but how can i carry out a test on it? eg 4 wires plug, when should they be onn or off?
Earthing wire cluster for injectors checked, seem ok.
Questions:
Does it matter which way the injector connectors are connected, eg there are 2 dimples on one side of the connector, should the dimples face up or down?
Have you any ideas what or where the problem is?
We have had the car for 2 years and are at our wits end to solve this problem.
Any advise would be most appreciated.
New HT leads etc.
Questions:
