mr rosher
hi to you all, and i hope one of you guys can help me here, im in the middle of redoing the timing on my e280 1993 straight six, as the idle is rough and when shes at 2500 rpm you get a cam rattle, and then i was asked by someone, are you sure you`ve got ( no one piston on TDC and not no six on TDC ) which got me thinking, theres no distributor so you cant check by this, if anyones done this sort of engine timing before how do you know if its on one or six as both pistons are at TDC at the same time,
thanks for any advice,
rod.
rod.
