Hi Guys,
Recently my 190E overheated due to the temperature switch failing causing the cooling fan not to function.
During it's replacement the garage done a block/pressure test and thankfully confirmed the head gasket hadn't been damaged.
Ok, but this is my problem. I'm finding that the engine is running too hot...
The temperature gauge seems to go and down when moving and idling (as normal I suppose...) and there doesn't seem to be any coolant loss.
But, what i'm finding is that when its raining and the car is stationary in traffic, mine is the only car that starts to let off steam from the bonnet when the water hits it.
I know this is common sense and the law of physics, but it never seemed to happened before the overheating problem.
I've noticed this happen immediately even on short journeys and when I've lifted the bonnet it seems that the engine maybe getting too hot .
This is not only very embarassing as mine is the only car steaming, but I'm worried somethings seroiusly wrong.
Can someone please help and advise???
