Engine warning light on but no Malfunctions listed
Paul Sander
Surrey
2003 SL600
Engine light came on today...no malfunctions. I have turned the engine off and left it for a few minutes but still on. Possible secondary battery or voltage issue?
Any advice would be warmly welcome...
There will always be codes if the light is on. You just need the right code reader to see them.
Didn't you just buy the car ? If so was it from a dealer ?
rifiki
Worksop
CLK W209 W121190B
Battery voltage? Had similar problems with CLK, around 5 starts it went out.
Paul Sander
Paul Sander
Surrey
2003 SL600
I don't use the car much so that what I thought it might be...are the batteries in parallel so I can take one out at a time and give it a charge without everything going dead?
And would the reset within the instrument panel menu clear it in case it was just a battery voltage glitch?
bembo449
gainsborough , lincolnshire
not a lot of point guessing , either take it back or get it plugged into , it cant be serious if its not effecting the running of the car
Stick a battery conditioner on the consumer battery in the boot :)
ajlsl600
france
get it on a ctek for a while 3/4 days if practical. ,see what happens these cars HATE low voltage, lots of issues go away when batts in good order,and if yr keeping that car,get star,then get familiar with it. u will learn a lot and save a B fortune. when issue resolved put ctek permanent wiring in front and rear. have it connected up any time car not in use. batt under bonnet only starts engine, far as i know. observe handbook on disconnection/re connection procedure
Steve@Avantgarde
Bristol/Somerset
The malfunctions screen in the middle of the cluster are for warnings like low screenwash, bulb failures etc. Its not a item listing specific code screen for warning lights, such as the EML. Its highly unlikely the EML has come on because of low battery voltage so I would say you need someone with STAR.
Paul Sander
Paul Sander
Surrey
2003 SL600
Many thanks....so....next question...where can I get a cheap STAR from...don't tell me from Uranus....
Paul Sander
Paul Sander
Surrey
2003 SL600
thks Steve...
ajlsl600
france
look on ebay if you like pm me and i will put you in contact with guy who supplied mine,and resolved an issue that came up without drama or cost to me 2 yr later..
Steve@Avantgarde
Bristol/Somerset
Most independents will be able to diagnose your car for no more than half an hours labour. Its a lot cheaper than investing £600 in a machine you wont know how to operate at its fullest capacity for the odd fault code.
And even then the clone stuff doesnt do or cant do everything you need it to do.
flowrider
SL500 (R230)
Buy an iCarsoft MB2, easily worth the expense at about £135
My MB-II works fine on my 230.
I seem to recal trying GLKs v2.0 on it and it was fine too.
www.ckinsurance.co.uk
