Engine warning light
Steve Connor
C220 143 2.1L
I have a Mercedes C220 blutec... Year 2014 W205 - engine warning light came on tonight should I be concerned??? Thanks Steve
Steve Connor
Steve Connor
C220 143 2.1L
What do you think smart ass?
ajlsl600
france
I believe the suggestion was has the car been connected up to diagnostics to see fault codes.
Engine warning light will almost certainly have triggered a logged code, event and as dash does not provide that info all else is guesswork at the moment. Is Yr rpm limited or the car drives normally.
How concerned you need to be will be clear when diagnostics info is revealed., not always. But often a relatively minor issue.
Steve Connor
Steve Connor
C220 143 2.1L
Came on for no reason... Have the car 2 years no issues with it.... Just wondering why it would come on
Steve Connor
Steve Connor
C220 143 2.1L
Ad blue frozen.... Services reader ad blue not moving
ajlsl600
france
And why that don't surprise me..!! I am guessing the system has a key on heater at adblue tank outlet.?. It really is a crxp system and makers should be held to a class action resolution
Anyway read codes go from there.
mioba
Nottingham and Köln
An EML indicated a DTC logged. Of which there are many each with its own solution.
In order to determine your level of concern you wont know until the codes read, fault diagnosed and thus whats needed to rectify.
So take the car to angarage and let them investigate..
Steve Connor
Steve Connor
C220 143 2.1L
Is the only solution to clear this error code via the diagnostic device? Ad blue meter frozen at 6300KM, Tank nearly full but not moving..... Discuss please
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
You might be able to clear the error code with a code reader, worth a try. But if something has failed the item will need replacing.
My advice is go to an independent Merc garage with Star & let them sort it out.
mioba
Nottingham and Köln
Clearing the code doesn't fix the problem does it. Sage advice has been discussed already.
Steve Connor
Steve Connor
C220 143 2.1L
  • #17
With star??
AndySlade
Tadley, Hampshire
C220 Diesel Estate, Sports Edition
Star is the proprietary Merc-Benz code reader system. That’s why you need a Merc or Merc independent specialist
ajlsl600
france
To avoid garage, at least In 1st instance icarsoft clear code if it stays off give car a good hard 30 mile run
U may clear adblue. Pump, injector? It that's it add anti cystalization addative n hope that's it.
Then like me keep icarsoft in car, and consider merits of keeping car with adblue.
ajlsl600
france
And as far as I can tell.. There are none?
