Erratic idle, cold start, 190e
johntom
i've just bought a '91 190e 2.0, auto, petrol (68k, totally original, in fact near mint). The car seems to turn over for a few seconds before starting from cold (although it starts straight away when warm) it then runs fine, however when warm the tickover is erratic between 500 & 1000rpm? Help?
Stevie A
Scotland
OVP relay being faulty causes hard starting and erratic idle. If ABS light has been coming on sometimes then more than likely OVP relay.
Make sure that your OVR is putting out the full 12v on pins 87.
As Stevie A says a common fault after a number of years, often bad soldering but also suffer from decay.
Malcolm
johntom
would the ovp relay cause erratic idle when warm? ps i haven't seen the abs light come on.
thanks Johntom
johntom said:
thanks Johntom
Yes it can cause that, and a voltage test would confirm, tapping the relay during test for a stable 12v out
Malcolm
