mick777cpt
- Mar 21, 2006
- Avantgarde/2001/C200K
Hello Guys
Just for info for those searching for MAF problems. I have a 2001 W203 C200K with 97k Miles. For the last year when the car has been left for longer than 12hrs, especially when cold it has an erratic idle on start. You have to put your foot on accelerator for the first 2 seconds as it sound like it might cut out.
Very Occasionally (every other month) the ECU light would come on and after investigation with my own tester it was always the MAF that had the fault code. The car had no other faults. Drove perfectly after start and kickdown was perfect.
I bought a brand new MAF from Merc and it is the Siemens type and not Bosch. Tried it and still no change and the ECU fault light was for the MAF again. In Dec I sent the car to MERC for investigation witht the new MAF and the ECU light on. They confirmed the fault CODE was the MAF but the car drove fine and the MAF was not faulty. They tnen took the throttle body apart and found it to be in a very dirty condition. They cleaned it all out for me, refunded the MAF and since then the car has been perfect. Started this morning at 5am temp was -5 and Sweet start with no foot required.
I put this on for info really, as sometimes these Electronic cars are not as clever as we all think. If you have problems like this save the money for the MAF and clen the throttle body out forst to see if that helps.
Regards
Mick
Regards
Mick
