Error code meaning 16fc00/16fd00
Wilko1977
C350cdi 2012
Hi, can anyone help in identifying what the Error code meaning 16fc00/16fd00 is for these codes?
And, what I then need to get repaired?
They are not MB specific fault codes , maybe Google search them ?
W
Wilko1977
C350cdi 2012
it mentions ad blue when searching
Well if you haven’t got Adblue then the scanner is a very general one . You need MB star diagnostics or something like icarsoft which will give MB codes
W
Wilko1977
C350cdi 2012
This scanner has been fine on car before, brought up all other errors no problem.
The car is basically kangarooing at low speed
rf065
Grossbritannien
Never heard of adblue causing kangarooing before.
W
Wilko1977
C350cdi 2012
Could it be an injector issue
mioba
Nottingham and Köln
If you are not cofident deciphering codes, then leave it to a competent garage, adblue, injectors so on will inevitably lead to chucking parts at the car that are ok and wasting money.
what code reader are you using.
You need something to read live data.
I started with a cheap ODB bluetooth scanner and an app on my phone, soon reaslised it was 20 quid totally wasted if you like car maintenance, soon got an icarsoft and the data and depth of analysis are worlds apart.
W
Wilko1977
C350cdi 2012
Scanned was £175, has been fine before on other error codes, just other than these mentioned, no other error codes are present
mioba
Nottingham and Köln
have you tried deleting the codes and seeing what happens, comes up next
W
Wilko1977
C350cdi 2012
I've deleted the codes, will try tomorrow znd see how xar runs
