Error code, P244A7A Pressure differential of DPF too low
Tim Wicks
New Registration
Vito 116 CDI Dualiner 639/A
My engine management light has been popping on and off for months now. No pattern too it either. It can be on for a 10 minute drive and off the next time i start the vehicle and vice versa. It can drop the van into limited revs and then literally u can stop at traffic lights turn the engine off and restart the inginition and it will drive fine.
No warnings are coming up for a dpf regen, in the past it did require a reflash and forced regen but then ran fine.
I have had the error codes read and it come up with a historic P244A7a
State: Historic
The pressure differential in the DPF (cylinder bank 1) is too low. Leakage or a defective seal was detected.
Any advice would be much appreciated, and any idea of what sort of cost im looking at to correct it?
Tim
Looks like a possible leak in the exhaust system. The only other time you get this is when the DPF has been gutted.
Pcurtis64
C class 2012 c220
State: Historic
Tim
Hi Tim did you manage to get it sorted got the same code on my c220 but eml staying on any pointers will be much appreciated
Paul
Tel: 020 8863 9233
