ESP Inoperative W204 C180
CITYBOY
Cheshire
C Class C180 Blueeffiffiency 1.8 W204 {2012}
Good After noon ,this morning I a experienced a ESP currently unavailable , message on dash along with two skidding car symbols, I have recently had four new tyres fitted,although i have done some mileage since. Can anyone give me some advice
bertb1
C220 amp sport 2013
Abs sensor on the wheel would be my guess
C
CITYBOY
Cheshire
Thanks for the help, do you think that the tyre change in anyway could have caused it
bertb1
C220 amp sport 2013
I doubt it
bertb1
C220 amp sport 2013
I think low battery can also cause this
Some of the clever lads on here will give you more advice but with me it was the sensor
Cole@MBS
www.mbssouthampton.co.uk
We do 3-4 wheel speed sensors a week here, we keep 2 sets in stock they're that common, pattern parts don’t work from what we have seen, get it scanned, the ESP units can go down but very rare!
RhodieBill
Central South Coast. (Previously Out of Africa).
2001 W208 CLK320 182U ALMANDINE-BLACK METALLIC
Hi. Could be ill-informed here but I heard that a couple of full left turn and full right turn of the steering wheel can get rid of this - obviously whilst stationary and engine running....??? Nought to lose in trying I suppose.
C
CITYBOY
Cheshire
Hi Cole, are you saying it could be the speed sensors, also do you think the tyre fitters may have touched something when they replaced all the tyres
mioba
Nottingham and Köln
As Cole - buy genuine.
I once got patten on my w220 - failed after 7 months. Totall rubbish since the originals were 14 years old.
I also had module fail. Expensive.
Code read will point to the sesnor.
C
CITYBOY
Cheshire
Thanks everyone, not solved it yet but tomorrow will take it back to tyre place to see if they have touched something
bertb1
C220 amp sport 2013
Good luck
I doubt very much if that have touched something that they will admit it
You need to get in plugged in a merc specialist and they will find the fault
I was unlucky and damaged the abs module
I got it sorted and the the other sensor broke around 6 months later
mioba
Nottingham and Köln
Speed sensors are screwed in one end plugged at the other, nowhere near to what is touched at tyre change, unless the tyre mecahnic is throwing the tyre iron about like a monkey.
If something was disloged at tyre change time
it woukd have triggered a fault straight away.
C
CITYBOY
Cheshire
Thank you all, it was indeed the wheel speed sensor
Tel: 020 8863 9233
