ESP Programming and Air Suspension Compressor Override Module
zipster31
W639 Viano 2007
Hi folks. I have 2 issues if I may.
First issue: The ESP module needs reprogramming apparently. It's failing to communicate with the instrument cluster. Does anybody know where I can get this programmed (diagnostic shop said the ESP module may have been changed and does not have the same vin number as the original.
Second issue: I have replaced the rear air suspension with springs. How to override the fault light on the dash? Do I need a diode of suchlike in the air compressor circuit? Or is there a module I can buy that wires into the same circuit somewhere?
Thank you in advance:)
mersum1es
Finland
Car is Viano?
Z
zipster31
W639 Viano 2007
Yes, Mercedes Viano W639:)
V6Matty
Newark, Nottinghamshire
S212/10/E350(His) W169/2005/A180 (Hers)
Get it on Xentry and have the car told it’s no longer got that option, error will automatically go away.
Z
zipster31
W639 Viano 2007
Thank you for the reply. Do you mean get the ESP reprogrammed by Xentry?
V6Matty
No, the ECU for the car to tell it you no longer have rear SLS.
The ESP needs further diagnosis as it should be plug and play unless it actually needs SCN coding, at which point you can only do that by using online STAR
Z
zipster31
W639 Viano 2007
So I need to have the ECU tested by Xentry?
V6Matty
Main ECU will need to be connected to xentry and have rear SLS coding out, easiest way to do that is to change the model designation to one that didn’t have it as standard. For example on a car the estates have rear SLS as standard, if they were removed and switched to standard springs then the easiest way to stop the error popping up would be to tell the cars it’s no longer an estate but a normal saloon.
