Evening all
Simonium
Cornwall
S211 / 2005 / E500
New member and MB owner from May last year.
I am hoping someone here can offer some help. I have an extremely temperamental S211 E500, which we love (well my wife loves and I currently tolerate). I wanted a V8 as a last hurrah before we are doomed to drive milk floats, and was advised a S211 E500 because the engine and gearbox are very durable and reliable, and because only an E class estate is big enough (well a Volvo 240 would have been better in that regard, but they're daft money).
It has been beset with issues after picking it up - most of which we have cured, and some of which we have not. It has a seemingly capacity for developing new faults - it has done exactly that today. I have set aside money for service, rectification, and maintenance both usual and extraordinary, but it's finding new ways of eating through that!
I have changed, so far;
Oil & Filter
Gearbox oil
Spark plugs
Pollen filter
Track rod ends
Tie rod ends
6 tyres (punctures!)
Front discs and pads
Front brake hoses
Battery- Varta so a decent one
2 new keys
NSR Air balloon - twice, one cheap, one Aerosus
All three suspension level sensors - genuine OEM sensors
Toothed belt & pulley
Underside cleaned and waxoyl'd
Front wheel arch liners & under tray
I now have three issues.
1) Suspension playing up - usually, but not exclusively, the front raising itself to its highest level, leading to an uncomfortable ride quality. It has been reset by the local specialist twice (using Star), but soon starts playing up again. The suspension does change height, and the raise car button by the gearshift will raise the back when the front is at its maximum. Voltages are apparently fine, and there are also no leaks, apparently. My little OBD fault reader iCarsoft MB v2.0 recalls no error codes. A diagnostic techie friend has suggested there is a valve at the back of the compressor which may be stuck and which could result in this problem as the air isn't being evacuated correctly. The compressor is also fairly noisy so I'm guessing changing that wouldn't be the worst idea in the world.
2) Gearbox issues - this is a replacement gearbox from a main dealer, not recently but not fifteen years ago, either. The car won't change gear on start up once driving, but if switched off, and then back on, will do so, most of the time after one restart, but will occasionally need two. There is sometimes also a huge clunk when going engaging Reverse and another when engaging Drive - this is when it's cold and won't do it again that day. A whine, which also goes away when the car is warmed up. No oil leak noted either from oil draining on to the ground, or when the car was in for it's waxoyling last month.
3) The dashboard display flickers, and twice has gone out altogether although that hasn't happened for months. I wonder whether replacing the auxiliary battery might be helpful here?
As you can imagine I have spent enough on this car now that I ain't going to concede defeat, and my wife is even more determined than I am, but believe me I have thought those thoughts!
I apologise for the dissertation, but I am hoping someone might have some suggestions that I can put to the specialist when I book it in next.
Thanks in advance!
Simon
Hello and welcome
I’d recommend you post some questions in the relevant technical area of the forum.
Simonium
Cornwall
S211 / 2005 / E500
I will do, but it's going to be three separate threads, and what I'm really looking for is the contact details of a really good specialist. I will copy this original post and post it in the relevant areas.
00slk
Cambridgeshire UK
2002 SL55 AMG, 2005 E320 CDi,
Hello and welcome.
I can sympathise with you, I have an s211 320cdi and it is set to bankrupt us. Trouble is I really like the car as it has all the right qualities I need, just not the huge appetite for new parts.
Possibly your car may have been wet at some point in its past life, of just built on Friday afternoon like mine was!
As above post in the appropriate section and you should get a proper reply.
Lovely car though :)
00slk
Cambridgeshire UK
AMF Automotive, if Alex can't fix it no one can ;)
Simonium
Cornwall
S211 / 2005 / E500
Hello and welcome.
I'm all for giving up on it, and consigning it to the file marked "Expensive And Unnecessarily Complex German Tat" but my wife really loves the car. It says a lot when 17mpg is the least irritating feature of it!
00slk
Cambridgeshire UK
My wife said to me to get rid of my s211, reverse rolls here Simon!!
Wearsafoxhat
Sunny Hampshire by the sea
E63 :S213, SL500 :R129 , V220
Hi and welcome,
My wife refers to my S211 as “The Hearse” and isn’t too keen on driving it.
Notice that you are in Cornwall, you could speak to Avantgarde Automotive in Clevedon, they offer good advice and are quite respected on one of the forums, though haven’t used them myself.
The Aux battery is primarily for the SBC.
You replaced the switches on the suspension but are the linkages free to move and firmly fixed to the chassis.
Simonium
Cornwall
S211 / 2005 / E500
Hi and welcome,
Thanks, I will give them a tinkle. I'm off to see another specialist tomorrow morning, hopefully they can help. I've spend so much money getting this car where it is now it would be shame if I didn't get get it sorted. MOT next month though...
SmartAmg
2011 E class coupe 350 CDI
