Raymondofro
New Registration
- Nov 3, 2021
- 2005 a150
I bought a 2005 a150 over the weekend and took it for a test drive and it was spot on,
The next day I took it up the motorway and back and did about 40 miles. That evening I realised a wet patch under the car and the whole underside of the car was covered in oil and the car was empty on the dipstick, I’ve taken the cover tray off the bottom of the car and checked to see where the leak is coming from, it’s not coming from the top of the engine or the filler plug as both these were clean.
I refilled the oil a couple of days ago and it’s already drained itself in that period of time but there’s no warnings on the system to show that somethings the matter with the car.
Though as you can see in the attached photo the oil is mainly around the bottom of the engine/ top of the oil pan but I’m worried could it be a blown crank seal as that’s also in the same area.
So I was wondering where else would it be likely leaking oil from?
