Failed evaporator temperature sensor SL320
r129MAN
Holbury Southampton
SL500-2004
After reading many posts on this subject I am sure that this sensor is U/S on my 1998 SL 320. Can any one confirm if this is a DIY job to replace, I am mechanically minded and can tackle most things. I know that the unit is behind the dash but exactly where, is it on the drivers side, can I access it by just removing the trim panel under the steering wheel. Any advise & photos/diagrams would be most appreciated. Thanks. If not a DIY task has anyone had it replaced by a MB dealer/expert and if so how much did it cost?
r129MAN
r129MAN
Holbury Southampton
SL500-2004
Hi Malcolm
Thanks for reply, if you have a work sheet would appreciate a copy.
r129MAN
r129MAN
Holbury Southampton
SL500-2004
Hi again Malcolm
Can you confirm if this repair is a DIY task. Thanks.
Hi again Malcolm
Yes it is, and I will find the info for you very soon.
A 98 car could be a 129063 or 064 Please tell me what one
r129MAN
r129MAN
Holbury Southampton
SL500-2004
Hello Malcolm
If you need to know whether its a V6 or straight 6 model then mine is one of the last straight 6 engined cars MERCEDES SL 320. REGISTERED 27/03/98. CHASSIS No WDB 1290632F166055. Thanks.
