Fan Speed Regulator Switch Stuck On.
benzsupra
Hi everyone,
Been having a problem for the past week. I turned my fans on to warm up and when i went to turn them off they wouldn't turn off! Now it doesn't matter where i position the switch the fan's blow. All the other controls work fine, i can turn the air con on, heat on, air direction etc but turning it off is a no no!! :) Any ideas on why this has happened? if not does anyone know how i can access the controls? I have had a quick search but i can't find a guide to removing the dash panels.
Oh i better mention it's an E300 TD W210 model :)
Thanks for any help in advance.
Ben
Hi Ben if the fan is running at max and cant be turned off then its normally the fan regulator thats gone short circuit
B
benzsupra
It is running at max yes, is there anything i can do to sort this or is it an MB main dealer jobbie?
