Fast speed wiper is not!!
Bedfordrl
Bordon,Hants
Merc 230 te, two 1983 Range Rovers and 1956 Bedford RL
Hi .
The front wiper on our W124 230te is ok on intermittent and normal speed,but on fast speed it seems to have a fit and goes all over the place.
Any ideas
Ta
Glen
Dec
Ireland.
W202
It can be very rapid indeed, is it leaving the usual area that it normally sweeps when in normal speed?
I rarely use the fast speed as I find it quite scary.
All depends on what you mean by “goes all over the place “
Dec
B
Bedfordrl
Bordon,Hants
Erratic and ponderous.
Is this speed in the M.O.T. ?.
Dec
Ireland.
W202
You could take a look at post #17 here
Open the motor and inspect the nylon gear, if all is well with that you will need to remove the mechanism to check out the linkage.
The link is for a W202 but yours will be similar.
Avoid using the fast speed for the time being.
Dec
B
Bedfordrl
Bordon,Hants
Wow!! thanks.
Dec
Ireland.
W202
Forgot to mention, be sure to lubricate the wiper mechanism as soon as you can, if your problem is striped nylon gears, lubricate the wiper mechanism may ease the problem and slow down the possibility of the fault appearing in the intermittent/normal speeds.
At least you have normal wipers for the time being.
Dec
Tel: 020 8863 9233
