Fault codes
aclem
Shaftesbury, Dorset
2008 (Sept) W204 C200 Elegance Kompressor Petrol Auto
Good morning
Just a quickie - If a brake pad sensor triggers a warning does it throw up a fault code that needs clearing once the pads have been replaced? (W204 C-Class, 2008).
EmilysDad
Bury Lancs
ML350
It just shows a warning on the dash that the pads need looking at (there'll probably be a good few hundred miles left). New pads & sensor will then stop the warning from appearing. ;)
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
No. A new sensor fitted will reset the light.
EmilysDad
Bury Lancs
ML350
so will removing it ;)
It appears that Mercs sensors ground/earth onto the disc like Ford did in the days of FWD Escorts so removal of the sensor prevents the warning. My Vauxhalls though used a sensor that went open circuit when worn through so shorting the two wires also prevented the warning.
Obviously the condition of the pads & discs need looking at (like in the olden days) before you by-pass the sensor. ;)
A
aclem
Shaftesbury, Dorset
Thank you EmilysDad. I have already replaced all the pads but I'm still getting the low pad warning, hence the question! I didn't replace the sensors, though, so that appears to be my problem now. Hey ho! I'll pick some new ones up on Monday.
You’ve answered your own question.
You need a new sensor
onefortheroad
uk.
Only way to get a mb light off is to leave the sensor plugged in and join the 2 wires together.
EmilysDad
Bury Lancs
ML350
My mistake then .... on my last car cancelling the message only worked until the next pedal press so I assumed they earthed on the disc. The message would cancel for the duration of the journey.
ajlsl600
france
Next yr we will have to tell the f car that new pads are fitted ..another £100 trip to dealer .practice bendin over,!!!!
onefortheroad
uk.
Change them this year then :)
ajlsl600
france
Planing .covid allowin to change the whole motor.!!!
