hi, i have recently purchaced a 1998 c250td estate. the problem im having is that sometimes when i open the car and try to turn on the ingnition the key doesnt take the lock off the steering wheel so i cant start the car. what i have to do is lock the car again and then unlock it and usually this works,but not every time. ive tried new batterys in the key but there is no difference and with me only having one key im worried that if this problem gets worse i may be stuck without a car to use.has anyone any ideas on how i can fix this problem? is it the key that needs replacing or the ignition barrell maybe?? any solution would be much appriciated thanks roger.
