finally problem solved
ianmaxtec
I recently posted regarding my sprinter van problem. Firstly thanks for all the suggestions. For those who did not read the original thread: I have 312 1999 sprinter 73K on the clock, and loads of services and oil changes (2.9 straight 5 turbo charged).
While driving I get a “tappet noise”(normally when on a motorway, while fairly motoring). This noise would disappear after a few minutes (providing you pulled over and let the engine idle). After talking to a few friends (all are qualified mechanics) the conclusion was that one or some of the hydraulic tappets were loosing pressure, and need to be replaced. So off to the local merc dealer, cheque book in hand and replaced all 10 tappets. So off for a burn on the motorway, and sure enough the same thing happened, sharp Tappet sound after a few miles on the motorway. So rocket cover off (again) cam and tappets removed and all oil chambers blown out with compressed air (oil filter removed). Cam and lifters (tappets) refitted, no sign of any wear whatsoever, and started the engine… sounds sweet….left to idle for a few minutes, up to working temp, all sounds OK and off again for a spin on the motorway, and sure enough tappet tappet tappet sound………………….At this stage I was willing to give up, until I spoke to a Welsh mechanic who looks after a large fleet of trucks…….after explaining the symptoms his first response was “what oil have you in the engine” and I explained I used semi synthetic oil (10W40) as recommended by Merc. He suggested changing the oil for Castrol ELIXIR 5W50 (pricey oil!), and guess what PROBLEM SOLVED no more tappet sounds…sweet…. can anybody explain why ??????
TVRTASMIN
West Yorks
W124
I can't see how changing from 10/40 to 5/50 can have such an effect.
How long had the previous oil been in? Maybe it just needed changing.
turnipsock
Port of Menteith
Not sure why. But when I bought a modern oil and put it in my 230TE the engine sounded a bit loose. When I went back to a recomended oil, the engine was back to normal. I guess the oil you are using now is just 'thicker' at the right temp.
I
ianmaxtec
The old oil had about 2500 miles, I change the oil every 3000 or so (I had been using 10W40 since day one !
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
Oil foaming is an issue with hydraulic tappets. Changing the oil type can solve this problem instantly, as you've found out
Nick Froome
www.w124.co.uk
I
ianmaxtec
never heard of oil foaming at the tappets, but I reckon blondie has hit the nail on the head.
Sprint'n'Go
Ashton-under-Lyne, Near Manchester
This is interesting as I ran my van on 0W40 mobil 1 TD instead of the apparantly standard 10W40 and experienced no problems. I have since bought 50ltrs of Millers synthetic 5W30 but haven't had a chance to put any into my van yet (but will be doing this coming week) but have put it into my dads camper van with the exact same engine and he says it sounds sweet (but that may not mean much as he is deaf, blind and dumb. Sorry dad!).
Hopefully I will not suffer any problems with my high milage driving as opposed to a camper that does 2-4kpa. I will keepyou all informed.
Tel: 020 8863 9233
