Finding a sensor
JONSCLK
Hampshire
Hi all can someone tell me where i would find the sensor(s) that trigger the bas and esp lights on the dash on my 2002 CLK (208)
many thanks
jon
:confused:
What problem are you experiencing?
If you getting the BAS, ESP & ABS warning lights up then the most common (by miles) source is the brake light switch at the top of the brake pedal.
JONSCLK
Hampshire
IT seems every now and again if you travel over a heavy bump or apply the break the lights come on and and car becomes unresponsive but as soon as you turn it off and on again its fine and the lights go out
Should be just the brake light switch. standard fault, easy to change.
Malcolm
