First day of ownership fault codes
i.welch
Aberdeeenshire
Sprinter 311 LWB
Hi folks, picked up 17 plate B class yesterday.
Temp gauge was running normal about 80-90 after two hours flicked up to 120 and then flicking back to 100-120.
RAC came out and read codes
P13c2
P267f
C25D
Can anyone advise what the issue could be?
Ian.
mioba
Nottingham and Köln
You can normally google the codes and get an idea.
What did the RAC person say and do.
Was your problem only the jumping temperature to call the RAC.
First step. Go back to the seller.
Seconnd get aquainted with a good MB independent.
I
i.welch
Aberdeeenshire
Sprinter 311 LWB
Yeah been on the phone to them and got emails confirming to book it into local garage for diagnosis. My local garage is MB Aberdeen so o should find out later this week. Then update on the result.
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
Some of those codes could have been historic.
Clear them and see what returns after a short run.
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
What happened after the RAC read the codes, did you continue your journey?
Mr Greedy
Leicestershire
E350/2011/OM642 265bhp
If bought from a trader (not private) the trader should sort this. At least under English law. You shouldn't have to lay to get this sorted..Good luck
Botus
S500/2010/500
outside temp issues can be a by-product of the diesel emissions scam
Mercedes and GM both used fake ambient temp information to fool the car in to running an enriched cold engine map (aka an illegal drive nicely emission fiddle). Whereas VW did a much better fix, the cars steering wheel isn't moving thus we can be driving only in the emission testing lab, now run the legal undrivable map.
With the other points raised by LostKiwi, I would suggest the car is correctly updated to the current software and any sensors NOx DPF etc. are fitted. it would be unfair to expect a secondhand dealer to know of and or have equipment to convert a Mercedes to the product the manufacturer should have legally released first time round
I
i.welch
Aberdeeenshire
Sprinter 311 LWB
Hi all just to update. Got home after RAC disconnected the sensor and confirmed safe to drive home.
Booked into merc on the 17th and also to get recalls done!!!
There is indications of a slight coolant leak around the water temperature sensor.
Does anyone know if the Mercedes me obd tool is any use? Was wondering if that would pick up any faults also.
I
i.welch
Aberdeeenshire
Sprinter 311 LWB
This is with a cold engine!
I
i.welch
Aberdeeenshire
Sprinter 311 LWB
Hi All, just to update. Water temp sensor replaced and all issues now gone.
Droverunner
West Cambridgeshire
2007 CLK 220 CDi Sport. 2014 S-Max 2.0TDCi.
Good result. Similar happened to Mrs D with her CLK the other week. Dramatic off the scale temp gauge readings and overheat please stop messages. I self recovered the few miles home and a few days later put in a £15 Mercedes OE temp sender and all was well.
