First post - W124 door glass thickness
LHM
Hi everyone,
Having recently purchased a 1993 vintage 280E, I've been going over it to see what needs doing - and the answer seems to be, "not much" :D
One thing I had noticed, though, is a lot of wind noise from the driver's door. A contemporary Autocar road test mentions that thicker door glass was fitted on these later W124 models - so out came the vernier calipers!
Sure enough, the driver's door glass is considerably thinner than that on the passenger side, so I assume that the driver's side was (incorrectly) replaced at some point.
So, can someone tell me if the same glass was also used in later 'E-Class' W124's - or was it specific to these '92-'93 'crossover' cars?
Thanks,
David
I think that you have found out something that we did not know here.
stumpy
various
Interesting - mine was windy, but I changed the seals and pulled the doors in a bit on the striker plates and it cured it. I have some fabric covered door seals for sale in light grey as it happens.
type49
I think some imported ones had 3mm glass as opposed to 4mm. Is all the glass genuine - do the marks/stamps all match?
E280T
I also think that my E280T is sometimes noisy around the front doors when i'm driving 160+ km/h on the autobahn. Which door seals should I change, the thick ones on the inside or the ones that are visible on the outside part of the doors?
octanejunkie
Clevedon, North Somerset
All sorts of Germans
Interesting...
My W124 was also a bit "wooshy" round the front door seals. I too adjusted the striker plates. Helped a bit, but didn't aleviate it totally.
I shall be interested if Mercedes fond a cure...
www.W140.co.uk&www.r129.co
