John77
- Nov 19, 2018
- E200 Estate 2011, 2009 SLK 200
I have Fitted a Reversing Camera, but it has a strange electrical fault. Everything went fine, turned on the ignition, put on the brake and put it into reverse, turns on all is fine. Start the engine. put it into reverse everything fine, but on reversing, every time you put the brake on the camera goes off. This only happens when the engine is running, but not when sat with just the ignition on and the brake on.
What is strange is that when you put the ignition on and put the brakes on the brake lights do not light up. Not sure if this is normal. With the engine running and in reverse the reversing lights are on and the brake lights come on, so it seems that it is something to do with the brakes lights. Maybe I need to change the eath for the camera to the body.
2016 Smart Car.
2016 Smart Car.
