fitting aftermarket head unit
mrwonker
Hi there,
experiencing a problem with my audio 10 head unit (problem posted elsewhere on forum) if i can't solve this problem i would be looking at fitting an aftermarket head unit, any advice on fitting this on a w210 e300 is there any adapter leads i need? etc... also is it possible to fit a head unit under the existing slot in the slot with the cover over it as a may be interested in getting a dvd head unit and lcd screen which would have to go in the original slot.
thanks.
I did answer your other post,, if you do fit another make or type,,you may have to cut pin 1 on the connector if you find that the speedo does not work as this can kill the speed signal,but if you fit a nav unit it will need this speed signal
If your CD unit is emitting the red fiberoptic light then the head unit may be OK,,I do not have one in stock at present to check
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
I have both Audio 10 head unit and a cd multichanger for sale, if your interested.
M
mrwonker
Hi thanks for your replys, not sure if i have been clear enough i know little about these units so don't know if i have the right information but from what i have read with the head unit pulled out of the centre console and the optical wire disconnected, switched on and the cd button pressed there should be a red optic out of the socket on the back of the unit if this info is correct mine is not doing so. thanks for the info on the possible speedo problem if i fit aftermarket could be useful to know, and thanks for your offer bigasotonuk but i think if i can't do a easy fix on my existing unit i will probably just buy an aftermarket unit as i do quite fancy being able to play mp3s etc...
Does the audio 10 have 2 fiber optic leads, in and out
M
mrwonker
so no easy fix that you know of then? oh well was worth a try, aftermarket unit here i come, thanks for your help, just posted another question about k40 relay don't suppose you know answer to that?
I can look it up for you, and I will go to that post now
