Fitting Aftermarket Parking Sensors - W203
R2e
Tunbridge Wells
ML320 2000 (X) Petrol/LPG
I’ve just fitted a set of aftermarket rear parking sensors + display to my W203, and thought my trial and error experiences might be useful for others. Unfortunately, I didn’t think of taking pictures while actually doing the work…….
1. Fitting the sensors
I used these sensors - http://abarnard.ecs2.co.uk/4004-reversing-sensors-with-digital-display.asp - which I colour matched as per the website instructions with spray paint from Paints4u, 2 thin coats of colour, one of clear.
Firstly remove the rear bumper strip which is held on with clips. It is necessary to remove the outer strips (which go round the corner to the wheel arch) first. Note that the end nearest the wheel arch is held on with a screw inside the arch lining, if you don’t remove this the little bracket breaks (don’t ask how I know this…!) though as the clips seem strong this is not a problem and the strip holds fine. Check the gaps between centre piece and corners as you need to recreate the same gap later, when fitting or you end up with the centre bit too much to one side and have to do it again (don’t ask how I know this either….!). Preferably use something plastic to lever off the strip to avoid damage. Incidentally, any scratches can be touched in by spraying a little of the paint mentioned above into the aerosol cap and applying with a small brush.
The centre strip has four circles (very faint) marked in the plastic to show where the sensors should be fitted. I found the centre of the circles by making a circle the same size with a pair of compasses, cutting out then holding in the circle on the plastic and marking the centre with an awl. I used a small drill to drill through from the inside, then used the hole cutter supplied in the kit from the outside. I cleaned up the hole with a knife (the plastic tends to melt slightly and stick) then fitted the sensors.
The bumper itself already has the holes for the sensors, though the outer ones have a strip of plastic across the centre of the hole which needs to be cut off with a sharp knife.
Feed the sensor wires along inside the bumper right to left.
Now remove the internal trim from the boot. There are round and oblong plastic clips holding this on, all work on the same principle and the centre part should be removed, then the clip itself. The rear part around the lock should be removed first then the nearside trim which covers the lamp and rear SAM.
Below the rear lamp is a large rubber bung which, when removed, leaves a hole which lines up with the nearside sensor, the sensor wires should be fed through this hole. It is possible to obtain a grommet for this hole, but I simply cut a cross in the middle of the rubber bung and pushed the wire connectors through. A dab of silicone will seal this up later.
Refit the centre strip while pulling on the sensor cables to tighten them up and avoid them being trapped. It is a good idea to fit one of the corner bits first and ensuring the gap is correct when fitting the centre
2. Fitting the control box
I decided to use a relay on the reverse light to avoid CANBUS or bulb sensor problems, this may or not be necessary. The relay and the control box were stuck with double sided tape to the rear SAM (which was detached to make things easier). The relay was provided with a feed from a suitable ignition switched power source, reverse sensing from the wire leading to the reverse light, earth and connection to the control box. The control box was also earthed and all the sensors attached. All wiring was done using ‘piggyback’ connectors, not elegant but functional, and they can be removed at a later stage. At this stage the system was tested by connecting the display unit, putting the car in reverse and approaching the rear from all angles while watching the display.
3. Fitting the Display unit
This is the tricky bit. The wire from the Display unit has to pass from the front of the car through to the boot. After much experimentation, the following was found to be the easiest method.
a) The console trim was removed, as was the radio. (This is covered elsewhere so I won’t repeat here). The speaker cover on top of the dash was removed (This simply levers out, but use something plastic to avoid damaging the dash.
b) The cover under the glove box was removed (two screws just below the front of the glovebox) and allowed to hang down.
c) The left footwell trim was removed. This is held on with a central screw hidden by a small cover, and two clips under the weatherstrip. It is necessary to pull the weatherstrip off to access and lever off these clips.
d) The front and rear door carpet trims were removed, these pull off, though the rear one is also clipped at its front end so pull up to remove then pull back to slide off the front clip. Below these is a plastic conduit where the existing wires run through to the rear, etc.
e) The rear seat squab is pulled up on the nearside to allow access to the bolt which holds the bottom of the rear seat back. When this is pulled back the wiring through to the boot can be seen.
f) From inside the boot, just above the wheel arch on the nearside, a large piece of foam is removed to allow access between the boot and the interior of the car.
g) The Display Unit was positioned on the top of the speaker cover and a small cut made on the NSF to allow the wire to pass through. The Display Unit wire is then fed over the speaker bracket and down the front of the console into the place where the ashtray fits. It is then possible to feed the wire through into the passenger footwell.
h) At this stage the Display Unit can be glued to the speaker cover using the supplied double sided tape and the speaker cover, radio and console trim refitted.
i) The wire is taken along below the glove box and down the side panel into the conduit under the door carpet trims, through to the back of the car and up and over the wheel well into the boot and connected to the Control Unit.
And that’s it in a nutshell. Obviously take care to route the wires where they will not be damaged, or get in the way of anything else, Tape wires together and tape to existing cable runs for neatness, and put everything back the way it was. A wedge shaped piece of plastic is the best thing to use for levering the various bits off, I used one that came with a Brodit mobile phone/pda holder kit.
I’m delighted with the result, particularly as the Display Unit matches the light grey dash on my car and looks as if it could have been an original fitment. I think the sensors look good too and match the paintwork very well. The pics show the rear strip complete with sensors, and the display showing an obstruction to the right rear.
DougE280
London, England
Quote "....The relay was provided with a feed from a suitable ignition switched power source...."
Hi Ron,
I'm looking to fit some "sound only" sensors, avoiding the need to run wires through the cabin of the car. I can fit the "beeper" somewhere in the boot or behind the cabin side panelling.
The relay, I understand, takes it "signal" from a reversing light by tapping into the wiring behind the lamp, but where did you take the "ignition switched power source" from??? Is there something suitable in the boot?
Doug
Where is the fuel pump relay on your car, this could well be in the boot or rear of the car that you are buying
John Kerr
Nr Folkestone Kent
W209 CLK 220CDI Sport
If you look at the rearsam unit there is a row of fuses,number 17 is the feed for the factory fit,just connect a spade terminal to this fuse holder that is all I did with mine and fitted an inline 16 amp fuse to the bypass relay.
Trophy1200
Scotland, Central Belt
From the original post by R2e
"I decided to use a relay on the reverse light to avoid CANBUS or bulb sensor problems, this may or not be necessary."
I fitted my system without a relay, purely fed from the n/s reversing lamp, no problem with lamp failure indication or operation of the sensors. The choice is obviously yours but they can be fitted successfuly without a relay.
DougE280
London, England
John, Malcolm, Kev and Lofty,
Thanks lads, this is one of the things I loved about MB ownership previously, conversing with people who actually know what they're talking about (and can write well).
I tried the V**tra forums once or twice .... but all they talked about was trivia - e.g. what was the best colour to paint your brake calipers - threads which would go on for page after page, with lots of photos!
With my E280, I remember having problems with the cooling fans. Asked the question, and within minutes my problem was sorted - with someone actually posting a picture of the fuse box - with the actual relay at fault arrowed!!!
Back to my CLK, which I assume will have canbus (or equivalent) wiring. I confess, I hadn't thought of the fuel pump as a power source for the relay (incorrectly thinking all the wiring in the boot would be lighting related).
Actually, I fitted some rear sensors to my V**tra last year and, despite the canbus wiring, took the power source -without a relay - from an unused socket (for tow bar electrics) in the spare wheel well. Taking power from behind one of the light clusters triggered the "bulb out warning" (and would have necessitated a relay) - but, happily, this socket was isolated from this feature. I simply identified the correct pin, with my AVO meter, and connected up. Worked perfectly!
Is my 2004 CLK (W209A) canbus wired?
Doug
majio220
I need advice from the profitional group
I have E280 2006 model and it effect by flood since tow month back i start clean it and repairing it but i found difficultly to get security system for it ,So
If you have security system of Mercedes E280 2006 please let me know ?Or may advice where i can get that ?
Notice that security system should be from used car not new parts because if it is new i have to program the car which costly
:rolleyes:
this my email:
alzaem3@hotmail.com
Best Regards For MB
I am just adding on this pot that you cannot take the feed from the fuel pump, but you can from the fuel pump relay, more and more cars have this in the rear of the car now. This is the favourite place used by tracker firms.
John Davies
New Registration
It is mentioned in the original post that the disassembly of the console / dash is covered elsewhere - can you advise where?
My car is a 203
Many Thanks
John
Bhavick
Lancashire, UK
Wiring parking sensors advice required
I fitted parking sensors to my W209 CLK and after a couple of months the diodes in the mercedes wiring loom burnt out. These diodes were located in the wires going into the tail lights and not the brake, reverse or ground wires that I connected to, to wire my parking sensors up.
I have now had my wiring loom replaced which has sorted out the problem and I no longer receive malfunctions on the onboard computer system. I want to connect my parking sensors back up ASAP but was wondering if somebody would be able to advise me on if my parking sensors were the cause of the diodes blowing? Or was it just a coincidence because the problem only occurred a few months after I originally installed my parking sensors.
Anyway should I use relays when I connect my parking sensors back up to my car or will I not require them? If so, what size use I use? e.g. 10A, 30A, 40A etc
Thanks in advance!
I cant see that the parking sensors could cause this fault, they are very low current devices.
The problem in using relays is that the current used could be the same as the sensors,, an electronic switch maybe, but as you say you are using the rear lights , and nothing else.
I will sleep on it
cleverdicky
MB
Has anyone fitted aftermarket sensors to the front as well?
Wondered where best to take all the wires through, also is it best to trigger from the rear + delay or fit a switch?
Have front panel off at the mo' ready to fit so considering doing this soon.
jackwall5
Vienna. Austria
W203 C220 Cdi Automatic
Eventually, I've got around to doing the same following the excellent overview from R2e.
I had purchased a sensor set almost exactly as the R2e's. Time to get them in.
I painted them my car's exact colour prior to installation.
Installation took a few hours total with as mentioned by R2e, the wire routing of the display being the royal pain!
I used a spray primer first and Silver Brilliante 774U using a fine brush. A light spray varish to finish off a few days before the actual installation.
When all in and fitted, my test identified problems.
I was getting spurious readings ... all over the place .... checked all the wiring was OK, re-seated the connectors etc. I did not use a relay, just a wire onto the + of the Reverse lamp!
I was beginning to think I'd bought a dud !
Looking at the actualy sensors, I noticed that the paint had bridged the inner circular section with the outer ring. Could this be a problem?
Using a pin head, I broke the paint bridge between the inner circular section and the outer ring.
Result: No more errors and everything seems fine.
Very happy overall with my handy work and thanks again to R2e and all replied and contributors.
Hope this account is useful to someone.
Safe Driving
Yes, over painting the sensors will give false readings, the actual face of the sensor resonates at 22khz, if heavily painted they cannot resonate.
Normally just a light dust coat of the colour is all that is needed
Rappey69
hants
c220 w204 amg sport
I have a merc parktronic (back up assist) system that i have yet to fit.
Its for a w203 estate.
I though a nice easy job for a warm weekends afternoon. How wrong could i be !
I have the fitting instructions and it says i have to remove the rear bumper to fit the sensors:shock: I do get 4 templates to get the exact placement of the sensors in the bumper.
The rear interior light gets replaced by the new unit which has two extra reading lights and the parking sensor display built in. Now that part looks very nice .
Its the rest of the fitting that looks very time consuming...
this system plugs into the rear sam unit and requires a 5 amp fuse to be added.
I searched online for this system and it appears it retails around £850 :shock::shock::shock: then possibly another £400 for fitting :shock::shock:
The price for the front is much much worse....
angelina104
i think it is not hard for us to install the parking sensor, It is just time-consuming, My husband took one afternoon to install a parking sensor in his BMW E46 ,he was thole to do that. And that parking sensor was which i bought for him.
He just do as the user manual described.
I never thought that there would be so many probs for the compatibility of parking sensors. Isnt that the way, all the parking sensors can be fitted in the car?
:Oops::Oops::Oops: oh oh oh oh
angelina104
I did the same on my A class, and did remember to take the photographs see my page 64
lofty
http://www.aclassinfo.co.uk
I never try to install an aftermarket parking sensors myself. A time consumer for me, My husband always fits it, and we just purchase some non oem parking sensor kits on ebay. sometimes we tried do ourselves, sometimes my husband will drive to the car care center to complete it.
:Oops::Oops:
