I have an issue regarding a flashing right breaklight if I indicate right. Left side is fine with no issues. It is a 2004 109. Any help would be appreciated.
Just a quick update on this issue. Tonight while driving with the lights on, indicating Right makes the both indicator lights flash as well as the right brake light. Will check over the earth issue tomorrow in daylight. Thanks for the suggestions to try guys.
It is an earthing issue as per recommendations above. If you take your light unit out you might see damaged/burnt out connections as they can be under-specified from new.
