Flashing engine warning light
Adam Clairmonte
Sprinter 212 2012
Can anyone help?
I have a 2012 Sprinter Luton 212 and the engine warning light flashes causing it to go into limp mode. I have taken it to a mechanic who changed a sensor and it worked fine for 100 miles or so and then it happened again. I then took it to a commercial vehicle specialist who thought it was an air leak from the manifold. They then found a faulty gasket and thought they had found the problem.they changed the gasket and it was fine for another 100 miles but then it happened again!
I have spent nearly £1000 trying to get it sorted and am running out of funds!
Any ideas?
Frontstep
T210 320cdi
I have to say the hundred miles reference gets me.
Fault codes read seems to be the way ahead, where about's are you ?
