FM signal booster
mr_r
hi im looking for help on getting a signal booster for my 2002 c220 cdi
i have an after market pioneer dvd player.. but have lost my radio signal :-?
its quiet annoying any help would be apprechiated.
M
mr_r
thats a bit confusing for a first time buyer...i have been lost with all that.
but from what i did pick out, origanlly i had the factory fitted cd player.it all worked well with this .
i changed to a pioneer after i bought the car...since i have replaced i have lost tghe signal boost...the frequancy is messed up i have no AM radio and only one FM station.
brandwooddixon
Wolverhampton
S63 Coupe 2014
It is most likely that the cetral wire in the coaxial cable to the antenna booster in the C pillar has broken.
Prise apart the arial connector which plugs into the back of the radio and check that first. It is the most likely place for the aerial conductor to break.
A simple check and a simple soldering job to fix - just ensure that the earthed shield isn't shorted to the central wire.
M
mr_r
Brandwooddixon thanks for your reply...but i dont have the foggiest idea of what your talking about ..lol
no the wire seems to be fine...when i got a mates signal booster (for VWs..on Ebay) it worked fine untill he let the booster go ..and left it hanging. the frequancy went again.
The amp booster is built into your car,,if it was OK before you started messing around you will have broken the wire inside the plug the goes into the receiver
philharve
Falmouth, Cornwall, United Kingdom
go.to
W202 C230K Auto 2000
No/very weak radio signal on all bands: 3 x FM +MW +LW
Hi All
I have a Sony Radio+CD+Tape unit (CR-C5300R) in my 2000 C230K and it has worked fine probably since purchased new almost 10 years ago. The CD and Tape work OK and every button function operates faultlessly. I even reset the internal processor and reconfigured it without issue.
However, during the last week the radio receiver has decided not to work. It's not dead, far from it, because if I wait long enough I hear faint transmissions which increase and decrease in strength. Mostly all I hear is noise. If I were to describe the symptom in simple terms I would say the radio has lost its connection with the antenna. I do not believe the radio receiver is faulty because it is trying to work but the signal is far to weak.
I have touched nothing so broken wires is unlikely. However, I am aware there is an antenna booster inside one of the C-pillers and this maybe at fault. I am wondering if this pre-amp is fused and whether that could have blown. If there is a fuse, where should I look? In which C-piller is the pre-amp, viewing the car from the rear?
Assuming the worst and I have to replace the antenna booster, how much is it likely to cost me and are they readily available from dealers?
With a little luck the loss of signal may just be an iffy connector problem and retightening it will restore the radio.
I like music when I drive so I am beginning to miss it. However, I have CD and tape to fall back on.
REGARDS
Phil
Yes there is a fuse for this,,but I think that something else uses it as well,,I will check as soon as I can
philharve
go.to
Hi-Fi unit fuse
Hi Malcolm
Presumably the rear windscreen heater doubles as an FM antenna so would the Hi-Fi unit share a fuse with the heater. It sounds unlikely but ...
REGARDS
Phil
drdre78
london
mercedes c200 200
hi if you have install poiner radio and it not good.i have found sometimes poiner radio dont work as good.so i would try the merc radio back in there
Hi Malcolm
REGARDS
Phil
No way,,they are independent things. I will try and look it up
What year is the 203 please
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Phils car is a 202 malc, it will be a 202024 i believe, i always believed the "c" piller amp was fed from the stereo itself, i will very interested in what you find as my radio reception though not lost is very weak in my C43.
Thanks for that info Andy :D:D do you know the build year please 94-97 97-99 or 99 on please
bigasotonuk
Southampton UK
Phil's motor IIRC is on a "W" plate, so it will be 2000 model (maybe a 1999 depending how long it was before it was registered) though 99-2000 should be the same.
Yes the amp is in C pillar,,on all of these things to test. Unplug the lead from the amp that goes to the radio in the front and tune into a weak radio station,,take a thin nail or pin and while standing outside the car touch the center connection,if the radio springs to life then put that plug back and take out the aerial lead from the amp and put the nail while still holding it into the center pin of the aerial socket,,if the radio springs to life, then the aerial is faulty,,if it is still poor, then the amp is US or a fuse has gone and I will check on the at now
If the lead to the radio is at fault,,you run the new one through the center console
bigasotonuk
Southampton UK
Info. for Phil, a new aeriel Amp from MB is approx. £34, when i enquired last a new aeriel lead from the head unit to the Amp in the "C" Pillar is approx. £10 from MB.
OK I have the info on the antenna amp that I can send you both
I cannot pin point the fuse for iit as it is not mantioned
So Email addresses please
bigasotonuk
Southampton UK
Just to confirm, the aeriel Amp is in the drivers side/RH "C" Piller, Malc can you confirm this, as i was convinced it was on the other side, took it all apart on mine and i could,nt find it
bigasotonuk
Southampton UK
I thought the Amp was fed from the stereo itself, so this maybe why there is no info.
E-mail is
I have the info for you..Email address please
