Foot brake tends to stick slightly.
Dean Fletcher
Penrith, Cumbria
Mercedes E400
Hi chaps,
What's the best way to tackle a sticking handbrake / footbrake. When I park up at night I apply the foot brake then I go to it the next day turn car pull the handle to release the parking brake and the car sometimes doesn't move I have to give it a little movement then a little jolt happens to free it up then all seems well. I'm thinking the caliper piston is seizing up. What do you think the best way to tackle this is and any instructions would be greatly appreciated. Thanks
It won't be a caliper piston as the parking brake doesn't use them.
There is a pure mechanical linkage from pedal to drum brake shoe (inside the rear hub). The usual issue is a sticking pedal or sticking linkage under the rear seat area.
onefortheroad
uk.
Get under the panel and apply a penetrating spray to the workings as you press and release the footbrake. Maybe nip up the handbrake shoes and aim for 8 clicks should improve it alot.
Dean Fletcher
Dean Fletcher
Penrith, Cumbria
Mercedes E400
Funny enough I counted the clicks last night at it was 8 exactly. How do you get to the panel?
NBurns
Sunny Hampshire by the sea
www.facebook.com
A180 CDI AVANTGARDE SE CVT,169.007, 2009
I've got a similar problem with my foot brake. When I pull the handle the warning light doesn't go out immediately. Sometimes I have to pull a couple of times for the warning light to go out.
Once you've got it sorted stop using the parking brake - my smart used to stick, cleaned it stopped letting it rust on overnight and not had an issue since - autoboxes (assuming parking fairly level) don't suffer from being put in park.
ajlsl600
france
linkages .. take it to bits clean lube ,simples in my experience this is not unusual
as above i dont use mine much anyway P is pretty effective
I disagree. Use it or lose it.
If you use the parking brake regularly it won't get sticky nearly as quickly as if you don't. I'm not a fan of leaving a car sitting only on the park pawls in the gearbox.
onefortheroad
uk.
Push the seat back. Get in the car and bend your back and neck where the pedals are and look up .
onefortheroad
uk.
Pull the pedal up with your foot. Or spray the workings as mentioned and free it up.
CowleyStJames
Oxford
Mercedes-Benz E63s, Old knackered G wagon
If you don't use it regularly it'll start sticking.
You can lift the foot pedal with your foot, this'll release it fully.
Start using it a lot and it'll start working ok.
Mine was doing exactly as yours does, leading to an MOT failure. Mechanic sprayed silicon spray on back of release lever and pedal linkages to free it all up.
I now use it, even if not on a hill, and it works beautifully. These things don't like not being used
I use it regularly in driving and parking during the day, I just never leave it on overnight or for an extended period. Had a few issues with them sticking on in the past, not had an issue with it not working or sticking with my method.
If you go to any auctions and watch the cars being brought in the number with stuck parking brake shoes is high, into reverse and skid it backwards to free them is the standard operating procedure for auctions.
Dean Fletcher
Dean Fletcher
Penrith, Cumbria
Mercedes E400
I use mine everyday I live in a slight hill so need to have it on. Some days it's fine and other it's not so good. I'll have a look at the panel when I get time. I checked the foot pedal this morning and it bounces back like a virgins erection. :D
EmilysDad
Bury Lancs
ML350
All my autos have had their hand/emergency brake tested regularly every year for MOT. ;)
The only car I've recently had a sticky hand brake on was my previous 451 Smart & that was used every day .... the shoes themselves stuck in the drum.:confused:
EmilysDad
Bury Lancs
ML350
Actually ..... :) the electric parking brake on my W166 ML uses the disc & pads .... There's no drum, which surprised me.o_O
hopeful
clk cdi2.7 auto coupe 2005
as lostkiwi said adjustment under the seat ,brush it out liberally spay and check the return spring has not snapped ,easy fix if it has ( prise the remains away ,drill a hole in panel opposite the adjustment nut rearwards and attach a spring to the front cable mech
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
lift back seat in mine ,,there’s a inspection plate in the centre with a few studs around it once off you can see the linkage.
Tel: 020 8863 9233
