Graeme 1978
- Dec 28, 2020
- Location
- South Shields
- E220 2012 2.1
Hi still having a problem with my front driver side brake WELL a think it's the brake that's what a need help or advise with.
So the problem is when a steer right am getting a noise which sounds like the brake pads are rubbing on the disc and NO noise when a steer left.
This is what I have replaced up to today.
Front discs twice, front pads twice, front wheel bearing and today a new brake caliper.
When the caliper and pads are off and turn the disc by hand there is a slight wobble if that makes sense all this noise started after a fitted the first set of discs.
So has anyone experienced this sort of problem before.
The passenger side is perfect.
Can the hub go bad or is it just the bearing that fails.
W212 2.1 auto deisel on a 12 plate.
Thanks for any help and or advice
Sent from my SM-A520F using Tapatalk
