front disc minimum thickness on 2001 ml 270
kebo57
Lanc's
ml270
Hi does anybody no the minimum thickness for the front & rear brake disc's
(Must keep one step ahead of MOT station)
Uncle Benz
West Sussex
Mainly Mercedes
According to my data, front disc min thickness =23mm rear =13mm
kebo57
kebo57
Lanc's
ml270
Thanks for the reply Uncle Benz
13 mm seems a bit thin I'll mic them up tomorrow if it stop raining
Your front are ventilated and the rear are not, hence the difference, the figures Uncle Benz gave are correct.
Malcolm
kebo57
kebo57
Lanc's
ml270
Yes that sound correct so if it fails the test I can argue the toss
Balal
Sheffield
SL 350 R230
Am I right to assume that if car passes MOT the brakes are fine and dont need replacement as they do a check on brakes!!! riiiiiiiiiiight!!!!!???
yes and no,my brake warning light came on driving home from the MOT....
kebo57
kebo57
Lanc's
ml270
Once when I took the offroader for the test the guy said that the vented front discs looked a bit thin, said they were worn
I said all discs are worn to some degree so what would be the minimum disc thickness for this car, he didn't no so he passed the car.
I'm not replacing my discs unless I realy need to
Thanks for the replies
