Front Fogs not working
Dosco
W211
Replaced the RH side complete unit with a S/H item from Dronsfield and replaced a blown lamp in the existing fog lamp.
Neither work and the 'Bulb Failed' indicator comes on.
15 amp fuse okay (located on the RH end of the Dash) and the plugs are firmly located in each lamp:(
Does anyone have any ideas where I should look next:confused:
Do you have a multi meter or little volt meter
The light switches often fail on the fog setting . I think that you need to check that the is 12v coming out of the switch first, and work back from there
D
Dosco
W211
Thanks for that I will check it out.
R
