Front shock absorber mounts - replace 1 side or 2?
DuncanB
W124/1992/300E
My w124 saloon needs a new shock absorber mount on the n/s, rubber has visible crack and it generates a (very annoying!) squeak. The o/s appears OK. Is it necessary to replace both at the same time?
rayhennig
1991 300CE-24 Sportline
Maybe not vital but desirable, given that they are pretty cheap and easy to replace.
My 2c worth.
RayH
DSK
CLS 320 CDI, S350 Bluetec
Same as brakes always change such parts in pairs as the other will be about as bad albeit not always visually.
DSK
I forgot to add, not all mounts are made the same. Usually the quality of the rubber and bearings (design dependent) is awful on cheaper units. Buy Lemforder where possible.
D
DuncanB
W124/1992/300E
I see you all concur - I will fit both sides and buy OE. One question as I have not done this before: when undoing the the top central nut the damper spindle should be held still with an Allen key (it is said). When re-fitting, a torque of 60 nm is required - does the spindle have to held whilst doing this and if so how is this possible whilst using a torque wrench and socket on the nut?
If you use the right tools for the job you can hold the shaft from below using two half clamps.
The average home mechanic won't have that tool so it's a case of using ring spanner and Allen key to approximate the torque then checking with a torque wrench once there's tension present.
