Fuel Accumulator
Status
Not open for further replies.
Rufus6946
Kent
I was advised over this forum that my starting problem with my E320 CE Coupe might be to do with my fuel accumulator. I have contacted my local mercedes dealer who states that my car does not have one. Is he talking out of his arse as I suspect he is?
teky
UK North East ish
your system is mecedes HFM multi port sequential so its a modern system, its mainly the bosch j/k/ke systems that used the accumulator
R
Rufus6946
Kent
Speak english for god sakes man.
Does this mean I have an accumulator or not.
If not then how can this be part of the starting problem? Cheers
GaryC
Manchester
Hello,
Yes, you have a fuel accumulator, which located beside the fuel pump.
But I don't know whether is the accumulator got problem or not.
Gary!
teky
UK North East ish
why dont you buy a haynes manual man
R
Rufus6946
Kent
I have got one do you not think I have looked in there before I posted this for annoraks like you. Sorry getting a bit ****ed off now.
teky
UK North East ish
your system does not have the accumulator thats for early bosch systems, newer systems use a none return valve in the pump and i get pd off when people make remarks like that
annoraks like you
R
Rufus6946
Kent
My car is a 1994 L reg so wouyld it have the newer system or the bosch and I did say sorry about being ****ed off it has been a hell of a day.
teky
UK North East ish
no probs m8 i know what you mean, yes your car has the new system, bosch was used on the smaller and much older cars :wink:
R
Rufus6946
Kent
Cheers muckka did not mean to upset.
teky
UK North East ish
no probs i had a bad day too, im going to upload some tech data on your car to my database so you can test all sensors give me about 15 mins and i will reply to this post with the url
NormanB
Portsmouth UK
Not that I have such a 'new car' but what is the absolute minimum a DIY would need in terms of instruments to follow those procedures the best I run to is a DVM - but wouldn't you at least need a code reader?
Have you got similar access to diagnostic info on my car?
Thanks.
teky
UK North East ish
code reader/reseter if pos but a multimeter is a must, i had for years managed with just the multimeter and was only forced into getting special diagnostic stuff because of the newer cars 2001 up over, a simple code reader/reset tool is enough
R
Rufus6946
Kent
Hi Teky
Just checked on mine and I have the old bolt on fuel filter. This apparently means that I have the old system with a fuel accumulator. If this is so which I think it is, what does the fuel accumulator do, as I do not want to spend £100 replacing it if it is not the problem.
Cheers
teky
UK North East ish
it a holding pressure sphere to keep the pressure there between the injctors and the tank sort of like a pre-fuel primer but dosnt cast any where near £100 more like £15 from a motorfactors
Status
