JoeHorner
- Aug 21, 2022
- 2003 W203 C270CDI Elegance
I've got a bit of a puzzle with the fuel consumption readings on our W203 C270CDI.
Basically, they're wildly optimistic. On a run to London and back last weekend the dash claimed 55mpg but a full-to-full check over the 562 miles travelled worked out at 44.5.
I've previously adjusted the gauge to its maximum 30% correction factor using xentry because it was claiming an absurd 70+ mpg but there's no further adjustment available.
Now, I know that the dash reading is never going to be perfect but a 25% error at maximum correction seems excessively optimistic!
Does anyone have any idea what might be happening? The only two possibilities I can think of are:
(a) It's leaking. But it would be a huge and obvious leak to lose 2 1/2 gallons over a weekend, which there isn't!
(b) The injectors are leaking / injecting more than the ECU thinks. But, again, I'd expect the quantities involved (25% extra average) to show up in pretty serious performance / smoke issues. It runs beautifully and the exhaust is clean. All injectors are also properly coded.
So, am I missing something or is the dash estimate REALLY that bad on these?
