Fuel emissions
kjm975
Junction 3 M25
Hello all,
Does any one were I can find the fuel mixture screw on my E220 on an M reg, it failed its MOT test today on fuel emissions (co at 3.5% but HC’s were within limits) she runs OK but sometimes faulters at idle and the tester was unsure where it adjusting screw was to adjust it downwards so if anyone has any advice it would be greatly appreciated.
Ther is no screw adjustment, its factory computer set.
Often a good burn out at high speed clears the system to get them through
kth286
E320 Coupe 95
kjm975
It is all electronic and relies on sensors for feedback for the proper fuel amount to be injected into engine.
That generation of car needs to have a good fresh Lambda probe at 100k miles.
Also if the plugs and filter are old, change them also.
The coolant temperature sensor often go out of spec and is an important sensor for correct fuel at any given temperature.
If you want help contact me on
kth286@aol.com
keith100
Toronto
w204 c300 2008 (Gone)
Known in Toronto as an Italian tune-up! Take it out and thrash it.:D
Thanks keith,I could not remember the country :D:D
My 300TE in Sweden was tested in the Winter with only 16k kilometers on it and failed the test. Went for a Drive locked in 3rd flat out, came back and it sailed through the test
K
kjm975
Junction 3 M25
Sorry I haven't replied to you, been a bit busy!
I did a quick engine service on the beast (new filters, plugs, oil change etc) and finnally gave her the Italian tune up and she passed OK!
So thanks for the good advice.
