Fuel filler cap and central locking 260e
nilets
northeast england
l have a 1987 Mercedes 260e recently my fuel filler cap and central locking have stopping working.
Normally they open and close on the door key.
Can anybody suggest solution please.
l have worked out how to open my fuel filler cap cover and the doors have to be open and closed individually.
Can anybody suggest the problem and what l have to change.
Thank you
Nilets
Ron Palfrey
C280 Elegance 1994
I think your 260E will have vacuum controlled c/l - controlled by a pump under the rear seats...
The filler cap is also locked with this system.
Sometimes a fuse pulled out will re-set the pump.
The pump itself may have failed.
Check if the pump is working, or when you get it working again, that all the doors lock - if one doesnt, then its likely to be a vacuum leak which causes the pump to time out then shut down.
Check each of the vacuum lines for a leak.
Good luck, Ron
wscheffer
Ohio, USA
www.scheffers.com
If the locks work the pump is Ok! As mentioned check for vacuum leak if no leak.
I know this sounds crazy but I am speaking of the actuator.
Remove actuator then blow and suck into it the rod should move in and out. :mrgreen:
Stevie A
Scotland
I think it's a fuse or the main pump has failed. The pump is under the back seat in my car but I don't know about your model. Check the fuse box first and change the fuse for the central locking.
Ron Palfrey
C280 Elegance 1994
You're welcome nilets,
Perhaps you'll be good enough to post details of the outcome please.
That way we all learn something.
Thanks,
Ron
wireman
lancashire
I found a dud actuator on one of the rear doors, you could hear it hissing when the pump ran.
