Fuel filter
Seaforddean
Seaford
C220 sport bluetec 2014 2143cc
Just been advised that as my c-class has hit 100-000miles it should have the fuel filter replaced, is it as straightforward as it looks on videos to replace,
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Pretty much , the system primes itself using the ignition on and off 3 times with a 10 second gap. Just make sure to check for leaks after you get done.
mioba
Nottingham and Köln
...and use the correct fuel clamps. Not jubilee clips.
daibevan
Alltwen, Pontardawe
W203 C200 Kompressor Elegance SE 2006 Tanzanite Blue with cream interior
How often should you change the fuel filter? I've done nearly 40 000 miles since mine was changed.
mioba
Nottingham and Köln
40 is a good number. Get it changed.
The MB intervals are rather long.
onefortheroad
uk.
Around 40k possibly 60k or 5 years
Funkyboy
Liverpool
E250 w212 14 plate
Buy a set of CLIC r pliers off Amazon for £6 and watch YouTube how to use them. Makes getting the clips on and off so much easier
onefortheroad
uk.
I unclipped with a small screwdriver and mole grips and re clicked using small mole grips . Doddle .
daibevan
Alltwen, Pontardawe
I'd probable bu@@er the clips up causing a fuel leak and wouldn't be able to find suitable new clips for days, so for 6 quid I'll get some Click r pliers when the time is right.
onefortheroad
uk.
You can also use proper fuel line jubilee clips instead if you wish. Screenshot_20230410-144629.png
Chrishazle
Nr Ashford, Kent
On all 3 MB's I've owned or own (2001 S203 C270, 2008 S204 C220 and 2008 SLK280) the MB recommended fuel filter change is every 4 years.
onefortheroad
uk.
