humpty
iam an owner of a 1996 c180 and have a problem with the fuel guage showing full then empty then back upto full does anyone have any ideas how to solve the promlem
You have two sender units (the tank is in two halves), each one located at the lower front of each half of the fuel tank, accessible from underneath the car. There is a bolted-on cover over each one. Their position on the lower part of the tank of course means the tank must be empty (or as near as dammit) before removing. When removing the left-hand sender unit, you will have to disconnect the internal pipes connecting both sections of the tank.humpty said:i have been told it may be sender could you tell me where this can be located as i have looked in boot and under seat but to no avail
thankyou very much this as been a good helptom7035 said:You have two sender units (the tank is in two halves), each one located at the lower front of each half of the fuel tank, accessible from underneath the car. There is a bolted-on cover over each one. Their position on the lower part of the tank of course means the tank must be empty (or as near as dammit) before removing. When removing the left-hand sender unit, you will have to disconnect the internal pipes connecting both sections of the tank.
