fuel leak
traviski
hi all anybody tell me how easy it is to fix a leaking injector seems to be leaking from the bottom of the injector ie as if the seal has gone would this be all thats happened and is this a part that can be bought seperatly
the car is a 202 c class 2 litre
thanx in advance
trev
Xtractorfan
S class
Yes check with your MB dealer the seals can be bought and are cheap
T
traviski
thanx 4 that are they an easy fix or is it very involved is it worth changing just the 1 seal or am i as well doin them all
Parrot of Doom
Manchester
If they're easy to access I'd do them all, however do try and find the torque setting for the injectors so you don't over-tighten them.
T
traviski
it looks an easy fix parrot as far as i can tell its the air pipe coming across from the air filter needs removing then remove the fuel rail which in turn pulls theinjectors out lol sounds simple mmmm
T
traviski
well thats the injector seals all changed 25 pounds something with the brass/copper sealing washers not to bad a job never done anything like it before so fingers crossed took it for a quick test drive an everything seems ok:smile::
