Fuel leaking!
Redfaced
Durham Uk
Mercedes 2011 coupe c250 Cdi blueeffiency sport+
Om651 c204 c250 cdi 2012
Can some one help me where this leak maybe coming from, maybe it's a common fault but I have deisel leaking and pooling around where coolant usually leaks on the fuel filter housing. The longer pipe running from fuel filter is soaking but no signs of breakage. There is fuel sitting on top of the filter aswell. Could a clogged up fuel filter cause a leak here? I have no fuel related faults.
The pipes going to and from the filter leak from the clips over time, you can cut them back 1/2 inch and refit with new clips but sometimes new pipes needed!! It’s pretty common problem!
R
Redfaced
Durham Uk
Oh ok nice one will try that. Someone used jubilee clips on them aswell will have to change them then aswell I guess lol
R
Redfaced
Durham Uk
Weird how the pipe is soaking under sleeve if it's from there though
