Fuel pump part no?
The Ben
as above really, does anyone know the part number for the fuel pump on the W202 c220 cdi...? im trying to source one!!! grrrrr
Thank you in advance guys.
mattkh
England
A160 W168 1999 1.6
Hi
It is
6040700001
for the distributor type injection pump.
Just read your post about running out of diesel. So do you mean a different pump or the injection pump ???
T
The Ben
erm not sure. The RAC guy said it was the pump by the fuel tank, he said they are a common fault and often goes out to W202 cdi's with this prob.... He undid a pipe going into the injector pump and turned the car and no fuel passed through and that was his deciding view.
mattkh
England
A160 W168 1999 1.6
.... The RAC guy ... He undid a pipe going into the injector pump and turned the car and no fuel passed through
Hi
Was this when the tank was empty OR after you had put some diesel into the tank.
T
The Ben
well basically I ran out of fuel, put 3 gallons of diesel in, turned it over until the battery went dead. Charged the battery , turned it over and over again, and gave up, rang RAC he came out. he tried turning it over a few times, he instantly said it doesnt sound like it had ran out of fuel. He took the engine cover off, he put some node on some wire(sorry for the vagueness, but I was just watching and not asking questions) that he disconnected and turned the car over and node was lighting up(I presume something to do with heater plugs). and all he said was " well its not that" .
He then he then proceeded to try the pipe which fed the injector pump to which he did explain that fuel would not come out the pipe if the fuel pump by the fuel tank is screwed. No fuel did come out the end and thats when he decided that the 'high pressure fuel pump' (is that right) is knakard.
