Fuel pump timing on 1999 312D Sprinter 2.9 turbo bosch VE
phasesonix
Does anyone know how to time the fuel pump on a 312D sprinter?
I can see a mark on the pump housing but no marks on the drive gear to line up with it.
Is there another way to find out where the injection point is for no1?
Once I know I can put a dial gauge in it and set it to the correct value
(.9mm?)
Thanks,loz
steve hw
Norwich, Norfolk
602 engine fuel pump timing
im sure you would have soughted this by now but if you havent, drop me a message and i will explain.
steve hw
Norwich, Norfolk
Hi,tried to send message direct but it would not allow. Not sure what notches you have seen. The timing is checked using mb hht or star. If the pump is to be removed, the crank is set to 12 degrees btdc, with rocker cover removed check cyl 1 on firing stroke Cam lobes on cyl 1 point opposite directions. Undo pipes and wiring to pump, 3 nuts and slide it out. There is a mark or spline on gear which lines up with A on the casing. Before a pump is refitted line mark with A and then turn the gear clock wise untill the free play stops. the A on the pump casing is at aprox 11 o clock. with all assembled, fine adjustment can then be made using allen key adjuster that points upward from casing. Hope this helps.Always change oil seal. allow aprox 3.5 - 4 hours. Prob 6 1st time. for mb documents and work instructions send me a fax number and i will fax it to you. All the best steve.
P
phasesonix
thanks very much for that-
Loz
tomasekas
New Registration
Trakai Lithuania
sprinter
Need help
Hello,
I had some problem with my MB sprinter 312d 2,9. I removed injection pump to raepair it. Bet today i'm trying to install my repaired fuel pump. but problem there is a mark on the pump but no mark on the drive gear !!!!
I see this old forum. So, looking for help here.
Brendan Lynch
Registered
312D sprinter. 1995 2.9 turbo
Where's the Allen key adjuster located. Thanks Brendan
