Fuse Chart w164
ml280nick
London
Ml 320 CDI Sport 2009
Hi there
Hope your well
Anyone able to assist with a fuse chart for the ML w164?
Your help will be much appreciated
Regards
Nick
Your fuse chart should be either in with the tools or folded up in one of the fuse boxes
ml280nick
London
Hi there
Thanks. I have checked:
Three fuse boxes. Is there any more?
Spare Wheel at the back
Your help will be much appreciated as getting no luck with MB
Regards
Can you say what the problem is and what fuse you are trying to find
ml280nick
London
Hi there
12v power supply (Cigarette lighter) with light around it and light in ash tray not working.
All other 12v supplies are working.
Regards
F46 rated at 15 amps in the rear load compartment fuse box
ml280nick
London
Thanks for your help
So the one on the boot? on the side? Are there numbers listed on the panel! Just hope its the fuse!! You are a star!
Look forward to your reply
Regards
Nick
yes that is the one and all numbered I think it will be a blue one, not 100%
ml280nick
London
cheers
will let you know!!
regards
nick
ml280nick
London
Your star!! 12 v is now working. Little light inside ashtray not working. Same fuse? And the elimination around the 12v supply
Looks like bulb is nightmare to change?
Regards
Nick
Pleased its working, the lighting is all on the same fuse and if anything like mine the socket will have to be replaced, but is it worth it
ml280nick
London
Hi there
Change socket? big job? as you said maybe not worth it but suffer from OCD!:)
The panel its mounted on will have to come out, I can check on how big a job this is the next time I turn on
