Fuse Diagram For c180
johnny_99
does anyone know where i can find a fuse layout diagram for a c180 kompressor on the net?
Thats a hard one, the diagram is normally in with the tool kit
johnny_99
the wipers on my wifes c180 stopped working i checked the fuses but to no avail,when i turned the ignition on again the display in the instument console tells me there is a SRS malfunction ,,could this be related to the wipers or have i misplaced a fuse
any suggestions welcome
If you had the key in the ign when you did this then yes it could bring the lamp on, it may go with a disconnect from the battery, other than that it will have to be turned off on a diagnosis test set
The stalk switch is the number one cause for the wipers to stop
