boys
E200CDI 1999
the little headlight is gone tried a new bulb no luck
where is the blessed fuse located???
and is there a fuse for each light???
you woul;d imagine if the fuse went the two lights would go
I have a feeling the lamps are fused individual, Useful in some ways, dangerous in others. the fuses are marked under the lid, don't forget that sometimes a bulb can go short circuit taking out the fuse.
The fuses for the lights are in the side panel of the dash next to the instrument panel. Its the flush fitting panel you can see on the end of the dash when you open the drivers door (can't be seen with the door closed). Prise it out with a screw driver. Its easy enough to check all the fuses to see which one is blown.
Stop looking for the Best Garage!! We are here
and have the best advanced solutions for you,
at Competitive prices.
Put us to test with any issue you may have.
