Gear Box lost Gears
Mercedes Max
Essex
Mercedes Sprinter 313 CDI MWB also Mercedes 311 CDI MWB
Hi I have a Sprinter 311 cdi 903 3t MWB. I reversed and as I was going to put Gear Stick back to first gear to pull away there was not First,Reverse or 5th !
I was left with 2nd,3rd and 4th !
Do you know what the problem could be?
Regards Andy
M
Mercedes Max
Essex
Thank you Bembo I have to have a look getting under the Merc. just getting some ideas where to look!
bembo449
gainsborough , lincolnshire
is it a dash mounted stick ? if so pull the surround off , you ma see something , I have a dispatch and not long since replaced gear cables so , otherwise look under the bonnet , passenger side , maybe have a feel around , it will be apparent if ones popped off pal
Jim2
1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI 3rd Merc 2018 E class W213
Certainly seems like the linkage or part of it has come off...should not take long to sort that out..
M
Mercedes Max
Essex
Cheers Jim !
ajlsl600
france
Lucky.simple fix ,advantage of manual shift.
